Can you ID ABS Bearing by its Color?
Old 08-07-2014 | 12:03 PM
RedBike08's Avatar
RedBike08
Stage III
Default Can you ID ABS Bearing by its Color?
I have an 08 Ultra with ABS and wire wheels. I just purchase as set of standard mag wheels that were taken off an 08 Ultra. I noticed that both sets of wheels have a black bearing with a HD part number (all the same) and a tan colored bearing on the other side. Can I assume that the TAN bearing is the ABS sensor on the new wheel?
Old 08-07-2014 | 12:52 PM
Hammerhead Pat's Avatar
Hammerhead Pat
The abs bearing on a set of wheels I had bought were a kinda green/grey color. The abs bearing also was set into the wheel a little further than the non abs bearing side. Hope this helps.
Old 08-07-2014 | 07:24 PM
hardheaded's Avatar
hardheaded
the one i have has a tan seal on one side and is wider than a non abs bearing.
Old 08-08-2014 | 10:26 AM
RedBike08's Avatar
RedBike08
Stage III
Thanks for the responses. I mounted the new wheels and rode it yesterday. The ABS lights worked as designed. I got lucky in my wheel purchase as they came off a bike equipped with ABS.
dgoodbmw
07-26-2017 10:10 AM
dfowler1
12-19-2013 09:03 PM
jwk784
03-21-2013 06:18 PM
dabo0652
01-30-2013 06:25 PM
UPSGUY
Wheels/Tires
10-25-2010 07:58 PM
Quick Reply: Can you ID ABS Bearing by its Color?
