Rear Brake issue, 2011 street Glide w/ ABS
Ok all let see what we have here.
2011 street glide, 80 k. w/ ABS Brakes
history of Brake issues, brake peddle losses pressure and down to boards, will came back when pumped up. pads good, was full of fluid, the peddle colapsed and fluid gone and with no leaks. ABS HCU good, added more fluid, bleed system, peddle back up, little stiff, now rear break dragging. replaced Master cylinder once, dealer says the ABS unit good, then were the hell is the fluid going and why the brake failure.
