I have a 1996 springer 21" that i was told by someone at a swap meet this would fit. after trying to put it on it is not the right fit. can anyone tell me if its for a newer model or even for a springer at all so i can try to sell it?
I actually didn't try to put it on because once I looked at my hub it was clearly different, mine also has a cable for the speedo that goes to it. I have read you can only use springer wheels on springers due to an offset. i have been looking around and it seems to look alot like the 99 and down for a non springer but i am trying to confirm that so what happind to me doesn't happen to someone else.
That is correct springer's have a different offset. I had a 96 Bad boy and had ran into the same findings.
