Damn stubborn Harley brakes
Alright gents, forgive me as I know this has probably been answered before. I recently installed a set of 16" apes on my 07 Heritage. I have her all buttoned up and can't seem to bleed to front brakes at all. The brake lever is spongy all the way to the grip. I've tried all I know to do, tried a power bleeder, collapsed the pistons in the caliper, etc etc. I'm missing something and I don't know what it is. I currently have the bars all the way to the left, with the MC cover off, reservoir full and the lever zip tied to the rear trying to build pressure. I've read through the service manual that offers about a paragraph on how to bleed the brakes. I'm assuming since this I'm installing a new line that the bleeding process takes a bit longer than it would to simply change out the pads. Any help you gents can muster is greatly appreciated.
S/F
Molon Labe
S/F
Molon Labe
Exactly. And if you want total solidity, don't RUSH the process; let bubbles work their way up. Another trick is to not pump it, but just tap lightly not moving the lever far at all, unless you're using the speed bleeder. My HF unit works fine.
For a stubborn sucker, top off and let sit overnight so all the micro bubbles come up to the res. You'll be surprised how much air was in there you couldn't see.
Again, some tubing from the bleeder submerged into a jar full of fluid and you have a speed bleeder.
