tires cracking
Old 03-04-2013 | 09:11 PM
lmosburg's Avatar
lmosburg
Stage II
Default tires cracking
I have a 2012 flhx and at 9500 miles I had to have my front tires replaced due to side wall cracking, this past weekend, Inspected my tires and found the front is again starting to crack, I now have 15000 miles on the odometer. I don't use any tire dressing, and have not used any soap and water on the tires. I kept in a shed, My last bike I owned I had replaced the front tires due to being worn out. I due nothing any different, what is the reason for the cracking?
Old 03-04-2013 | 11:38 PM
3408pete's Avatar
3408pete
That would depend----------------I would have to see the cracks to have a better idea.Sometimes if they are close to a electric motor or something else generating tire killing compounds they can crack faster.I have seen bikes parked inside a shop with a window that sun shines on them all the time do it as well.It also could be the tire as well just having a issue with sunlite.
Old 03-05-2013 | 06:30 AM
asm481's Avatar
asm481
Do you store your pool chemicals by the bike?
Old 03-05-2013 | 06:50 AM
ynots's Avatar
ynots
Did you check the manufacturer date on the tire?
Old 03-05-2013 | 06:13 PM
jfarrar30's Avatar
jfarrar30
My 12 did same. Dealer put on brand new tire. It's just as bad if not worse than what came off it. I believe Dunlop had a bad run of tires
Old 03-05-2013 | 07:49 PM
lmosburg's Avatar
lmosburg
Stage II
no chemicals at all in my shed, tire date is 0612, looks like the tire was about 6 months old when it was installed, myself and few coworkers feel it could have been a bad batch, anyway have an appointment at the dealer saturday.
Old 03-05-2013 | 09:04 PM
3408pete's Avatar
3408pete
I realize that dunlop car and truck is different from the bike tires but I know their quality has suffered since about 2009
Old 03-14-2013 | 01:45 AM
hanibal1212's Avatar
hanibal1212
Stage II
Default front tire cracking
Hello, I have a 2010 wide glide and my front tire was replace twice under warranty for cracking and splitting around the complete tire near the center.. I had the first replacement at around 800 miles then again around 1800 miles... I noticed a different tire on the newer glides and I believe it was a bad batch of tires...
Old 03-15-2013 | 10:15 PM
nytryder's Avatar
nytryder
One of my riding partners has a front tire on his 09 Ultra that is cracking. It is just over a year old. Dealer said not to worry. He has never seen one blow out. He's taking it to a different dealer. I don't trust any tire that is cracking, Period. Going to Michelin Commander II's on mine when they wear out or start the cracking.
slowrollin
01-11-2023 07:17 AM
Cahdek
07-15-2017 03:21 PM
rdam
03-08-2011 09:43 AM
SportyPig
10-19-2007 04:04 PM
BK Meyers
08-25-2007 11:35 PM
Quick Reply: tires cracking
