TIRE LIFE -need definite answer
A while back I was reading posts about tire life. The general concensus was that even though a tire still has a sufficient amount of tread, it can still get "old" and lose its gripping qualities. These riders switch out after 3-5 years. More recently, however, several guys were of the opinion that tread was the determining factor, moreso than age. They said going beyond 5 years was not out of the question. At this point, I need some real insight into this discrepancy of opinion. Has there been any testing or studies done on this topic? Maybe just personal experience would be of value. I'm sure those of you who've been riding a lot longer than me (10+yrs) can shed some light on this. Thanks in advance for your help.
Each tire mfg has a tire life expectancy, but not always and an expiration date. Most state a tire that is 5+ years old it is reccomended to be replaced. this is mostly due to uvUV deterioration. Bikers generaly will not install a 1-2 year old tire to begin with when there are fresh tires avail. As far as tread wear, most modern MC tires have wear bars ti indicate tire is worn out.
I have never come across any legally binding definition regarding tyre life, but the advice I have seen comes from various sources. Things like boat trailers and the like often do low mileages, get left outdoors and can have a tough life and the advice I have seen for them is to change at 6-7 years. I reckon that is the backstop!
As for cars and bikes I have seen shorter intervals such as five years recommended. Frankly if you inspect a tyre of that age you will probably find the rubber is getting hard and cracks are appearing in the sidewalls and tread. There are threads in HDF with owners of 2012 bikes having tyre problems!
I would be surprised if you will get a black and white answer. Be certain however that just because a tyre has a lot of tread on it doesn't make it safe! An awful lot hangs on that ring of black.....
Since tires are made with latex rubber which is a natural product, it will deteriorate at different rates depending on : Temperatues, humidity, sunlight and wear...There isn't a defenite answer because the variables are way to high...Bottom line is if your tire is at 6 years, you should change it...there are only 2 on the bike so why take the chance....You might be able to leave it on the bike for 15 years but are you gonna be the test subject? Not me...
There are a lot of determining factors on how fast rubber deteriorates. How much UV its been exposed to, etc... If the sidewalls shows signs of drying out (cracking) its time to change. 5yrs beyond the manufacture date is a worse case scenario. Ive seen the rubber stems on car tires crack a lot quicker than the tires
