Michelin Commander II = NOT IMPRESSED!
SO I have been running the Commander II's for about 700 miles now....DRY GRIP is awesome!! I'm as sure as anything in the dry! I can press my Deuce into corners so hard my pegs will start to drag and fold up under my feet.
Wet grip however, sucks *****....My Deuce breaks the rear end loose almost every time it leans.....Try to take off....breaks loose, stop fast, just slides...I have to make very calculated, slow, controlled moves in order to keep them hooked up....Give me no faith in an emergency....
These tires suck worse in the wet then any other tire I've ever rode and i've rode on a lot of rubber over the past 10 years...
I will not be using Commander II's again.
I have a Michelin Commander II on the back of my 2011 FLHX. Called Michelin and they said to run pressure suggested by HD.
I'm not impressed with the tire at all. I have about 5000KMS on it and will be switching back to Dunlop in the spring.
The rear end has kicked out on me twice in corners in the past 3 weeks (not even aggressive corners).
Just my 2 cents....
K.
Just my 2 cents....
K.
Just my 2 cents....
K.
Just my 2 cents....
K.
wet or dry?? My dry performance has been steller...it's been only wet issues for me....
All of my other bikes I usually ran at 40 and 40.....(the pressure they are at now is what the indy put them at when the tires where installed)
