Rubbing sound - Why??
Old 06-30-2012 | 01:18 PM
V-Rod Troy's Avatar
V-Rod Troy
2nd Gear
Default Rubbing sound - Why??
There is a rubbing sound from the front of my 2004 VRSCB that has 989 miles on it. The rubbing sound goes away when the front brake it applied. I don't think the bearing is bad... would the pads be bad already?
What can be causing this noise?
Old 06-30-2012 | 01:26 PM
RLE's Avatar
RLE
Thats just the sound of youre pads barely touching the rotor. When you pull on the lever the pads firmly grip the rotor, making the noise stop. Its nothing to worry about.
Old 06-30-2012 | 01:32 PM
V-Rod Troy's Avatar
V-Rod Troy
2nd Gear
Thanks
Old 06-30-2012 | 01:39 PM
checkers's Avatar
checkers
Nope, not a problem. Every Harley I have ridden does this. It is the brake pads riding on rotor. If there is no drag with wheel when raised and spun, noise is common and no fix needed.
Old 06-30-2012 | 01:47 PM
V-Rod Troy's Avatar
V-Rod Troy
2nd Gear
Thanks... makes me feel better as this is my first bike.
89richard
03-02-2017 12:41 AM
cajun1957a
Shovelhead
02-24-2015 08:25 PM
Alain
10-25-2014 06:55 PM
tread 2007 ultra
03-06-2012 09:18 PM
tumbleweed883
06-08-2009 02:11 AM
Quick Reply: Rubbing sound - Why??
