I did some searches but couldn't seem to see much on my issue. I have an 09' Fat Bob w/only 7K on it. My front brake lever doesn't seem to want to return where it should after using-hence keeping my brake light lit! Appears the piston is pushing back. Tried cleaning,lubing and it worked for a bit but by next day same issue. Any advice/suggestions truly appreciated as it isn't a particularly safe issue. Just wondering what I need to buy or do to correct. Thanks folks!!
I would guess that either the lever is dry and sticking, or the piston inside the master cylinder is sticking. I suggest you remove the master cylinder from the bike, strip clean and overhaul it.
Friend tore it all down..Brake fluid is brown/switch ok/lubed piston/ worked fine for a short ride but starting to stick again...7K??? Fluid WAS shitty looking....
I discovered the hard way, when I first owned a disc-brake bike, that it goes off very fast. Looks like old tea, even with a scum on top! Disgusting to look at. Change your brake fluid every couple of years at most.
Sounds as if your bike is on its way back to good health!
