Anybody here change there single disc brake over to a aftermarket setup? I had a Brembo oversized floating rotor and matching caliper on one of my hot rod bikes but I don't see them offered for the 2009 Dyna model.
The reason why is that HD moved the caliper mount up so they can use those twin cam calipers with 300mm rotors. No one I know is making adapters for the 2006 Dyna and above.
Yes, it can be done but not as easily and cheaply as you have done it before.
