'05 Ultra brake pulse
I have and 05 Ultra Classic with 14,000 miles on it. I bought it used thru a dealership on consignment. I bought an extended 2 year warranty (maybe one of the dumbest things I have done). It had only 8,700 miles on it a few months ago when I bought it and now it has developed a somewhat severe brake pulse on the front end and a loud squeak that pulses as well. The front pads are well within spec and were replaced the day I picked the bike up. The bike hasn't been ridden hard, wrecked or damaged in any way. Is this covered under extended warranty and how can I figure out what is going on so if I want to avoid the stealership I can get what I need and do the repair myself.
No need to remove anything, can you get the front wheel off the ground ( safely or course ) in order to spin the wheel. Mounting the magnet is a bit of a pain, you can use a piece of flat stock large enough for the base, mounted off one of the caliper bolts.
I will get a peice of flat stock from work later on and drill some holes for mounting and will try to check tomorrow. I work second shift and I don't have a shed or garage at my disposal so I have to wait until the weather is better. Anything other than a couple thousands would be bad enough to need replacing? If they need replacing, any particular style/recommendations?
can you take it to another dealer? wonder why they wouldn't be straight-up and tell you whether the rotors are covered? Although I agree with 1CdnHD on your issue more than likely being warped rotors, I have bought and replaced brake pads from HD that made my front end shake after being on the bike for about 3 weeks. I went back to the dealer with brake pads in hand and they gave me another set that I have on still today with no front end shake. that was about 7k miles ago.
Roadflyer
05-06-2018 02:18 PM
