anyone running MU85B 140-16 on rear of softail?
Its time for a tire. Ive been running a MT90/16 dunlop 402 wide white wall on rear. I was told to put a MU85B/140-16 on the rear, that it is a little wider which makes it handle better, has a higher load rating and is 11/32 tread verses 9/32 on the MT90-16. Is this correct and is anyone else running this size on a heritage softail?
If you have a later bike with narrow belt you should have enough room. Theoretically the 140 is 3/8" wider than the stock tyre, but the actual fitted width can differ from the nominal size.
As an example, my current Avon Venom 150/80 is 153mm wide. That is only 1/8" wider than its nominal size, but it can be the difference between success and disappointment!
