not holding pressure(brake)
when i built my bike and bled the rear brakes they worked fine.then the next day no pressure.after bleeding and bleeding i gave up and bought another new master cylinder.i am going through it again.i bleed the brakes and get pressure and brake light works.check it hours later and they are week.with just pumping the pedal maybe 15or20 times i get it back.sounds to me there is a leak somewhere.checked all lines and they are tight at the fittings.both banjo washers are beat up do you think that could be the problem?this is driving me crazy,please help
dromgoogle
05-11-2016 04:35 AM
elevenbravo78
EVO
14
08-29-2012 11:07 PM
