Car tire on a '07 Ultra
Old 02-27-2011, 12:21 AM
TooEasy's Avatar
TooEasy
TooEasy is offline
Talking Car tire on a '07 Ultra
Folks,
This post is intended for all those people that have emailed me and PM'd me about a car tire for baggers '08 and below. If you don't like the idea of a car tire on your bike, no need to read this post, no need to get all worked up over it. Nothing wrong with bike tires.
My riding buddy has been riding his '07 Ultra with a Vredestein Comtrac 175/75-16 car tire on his Ultra, with an OEM 16X3 rear wheel, no physical changes or adjustments were neccessary, and he is very happy with it.
He doesn't own a car (by choice) so he puts a lot of miles on his bikes and his tires, and rides in all kinds of weather.
The Vredestein is a close fit, little clearance on both sides of the fender but nothing rubs. He decided to go ahead and do it for the same reason I did: insane traction, wet or dry. Handles a load or overload like it wasn't even there. We know its loaded because the engine feels it, but the bike gets even more stable with more load. Did I mention a huge contact patch....???
He is running 36 PSI on the Vredestein and 40 PSI on the front D402.
The car tire is very forgiving when it comes to air pressure, but the front is still A MC tire, and the pressure has to be kept up there.
Couple of pics:
Regards,
Old 02-27-2011, 06:27 AM
09StreetGlider's Avatar
09StreetGlider
09StreetGlider is offline
Thanks for this post! I have some friends that will be happy to hear there IS a Darkside option for them...
Old 02-27-2011, 06:38 AM
moondog99's Avatar
moondog99
moondog99 is offline
So no rubbing running two up? Looks really close to the fender. Cool concept.
Old 02-27-2011, 07:23 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,144 Likes on 3,668 Posts
Damn that looks close....I might have to break bad and try it....My fender is a bit offset so i might have to tweak but damn....I will have to wait until i go through 4 tires i got deals on before i pull the trigger...I might find me a spare wheel and have 1 mounted....
Thanks for posting this.
Old 02-27-2011, 08:59 AM
latnyte's Avatar
latnyte
latnyte is offline
damn and just when i was sure i was out of luck for my 05 rk custom , time to really measure
Old 02-27-2011, 09:08 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Roberto, thanks for the info. I googled the tire to try and find out rim width information on it, and came up with this site and chart. No rim width is mentioned, but I think it is noteworthy that the speed rating of the "R" series is 106 mph. The Dunlop motorcycle E3's, in comparison, have an "H", rating, which is 130 mph.
http://www.tirefactory.net/comtrac.htm
Last edited by MNPGRider; 02-27-2011 at 09:59 AM. Reason: added speed rating R vs H
Old 02-27-2011, 09:07 PM
heavyhitter01's Avatar
heavyhitter01
heavyhitter01 is offline
Where did you get the tire from? I can't find that size anywhere.
Old 02-27-2011, 10:12 PM
Mr Cujo's Avatar
Mr Cujo
Mr Cujo is offline
Roberto,
I see that you mention you are running a 195/60-16 and your pal is running a 175/75-16
Are both speedos correct at this ? There is roughly a 4.25" difference in circumference -
Are you getting good clearance with the wider tire -- especially 2-up?
And how well does the different sidewall heights work out ?
If I'm doing this right, the 175 has a much taller sidewall and has a larger circumference, but with a narrower tread -- the 195 is wider, but shorter sidewalls and smaller circumference.
I wonder what handling characteristics will be different between the two ? or if it'll even be felt..
BTW, I found a Bridgestone Turanza in 195-60 that hits the H speed rating and 50k warranty.
HERE
Thanks for the hard work, and looking forward to more info-
Old 02-28-2011, 06:10 AM
Notgrownup's Avatar
Notgrownup
try www.tiresweb.com
Old 02-28-2011, 09:51 AM
TooEasy's Avatar
TooEasy
TooEasy is offline
Originally Posted by Mr Cujo
Roberto,
My rear wheel is 16X5, his is 16X3
His is correct now, with the bigger tire. Mine is a little off, my tire is the same diameter as OEM. Checked speed with the GPS.
No clearance problems two up and overloaded. Look for my initial post "Car tire on my Road King"
Which tire depends on what year bike you have. The 195 for 2009 and above and the 175 for 2008 and below, because of the rim sizes and the swingarm.
It has a very short learning curve.
HERE
I looked at that tire too, but the Dunlop SP 5000 is a sports car tire, TireRack.com classifies it as "Ultra high performance" so I went with it.
But there are people with Harley touring bikes running that Bridgestone tire, and they are very happy with it. They just don't come and post here because of all the negative posts.
Roger, thanks.
Regards,
Quick Reply: Car tire on a '07 Ultra
