How Do I Release My Mufflers
Hi Guys (Newbie Still Here)
Need new tires for my 1985 Electra Glide Classic.
So I figured I'd take the rear tire off myself ~
And GOD said, " YEAH RIGHT "
As you guys can see from the 3 attachments; I DON'T KNOW HOW TO
RELEASE the muffler from that connection that you see
Some Questions Guys:
1. Do I apply HEAT to one end and hopefully disconnect the muffer ?
2. Do I apply penertrating oil and then WHACK it with a plactic hammer ?
YOU TELL ME GUYS ~ I'M STUCK
Schooner, I can't say for sure as I have no experience on a "classic" Harley as yours, but viewing your pixs it looks to me that the header pipe and muffler just face up against each other with a gasket in between, and the one clamp keeps it all together. I would try using a putty knife and gently insert it into the gap between the pipe and muff to try and break the seal. Once started it should split apart pretty easily. Careful the muff doesn't fall suddenly to the floor. When reassembling scrape off all the old gasket material and replace with a new gasket, then clamp it all back together. Maybe if you post in the "classics" or "exhaust" forum you might get a better answer. Good luck!
If you want to get it off use a real penetrating oil like pb blaster not wd- 40. That's made for drying electrical wires and stopping squeaks, just read the can. Get a strap wrench , and give it a few turns in each direction. There's no official way to get them off so if you have to unscrew them so be it. I put a dab of never seize on the ends so the next time they'll come off easy.,,
Received 49,844 Likes
