""HELP"" 21'' to 16'' on 93 springer
You have an FX front end so you'll need a wheel that will take a 3/4" axel bearing. You can use about any 16" wheel you want, you can run it in either direction (unless it's a custom mag wheel with a pattern) so get one made for a single side rotor.
An FX springer has the brake rotor on the right and the FL springer has the rotor on the left like the Cross Bones. This is true for HD springers not sure about other brands.
