Front brake level
The switch could be sitting too far into the housing, also. There is a v-shaped copper tab that keeps the switch seated against the edge of the housing and if that is missing or has slipped, the switch may not extend far enough out of the housing to make contact with the lever.
If the controls have been disassembled recently, the other possibility is that the tip of the switch's plunger was broken off by the brake lever during reassembly.
