Brembo rear brakes on my 2004?
Late model HD take off parts are all over eBay, so I put Brembo calipers, rotors, & master cylinder on the front end of my 2004 Road King, no problem. Bolted right on & much better than the old brakes
Can I put Brembo on the back too? Or is the 2008+ frame & swingarm different enough to cause problems fitting the caliper/rotor? Will the Brembo rear master cylinder bolt on my 2004?
JR
JR
2004, 2010, brakes, brembo, brembo 2004, brembo older, brembo retrofit, davidson, harley, king, rear, retrofit, road, takeoffs, wheels
