Click click ......
Click click ......
I'm hearing a clicking noise from the rear of my 07 Road King....but ONLY when I'm pushing it back...like when backing up to park or getting it off the porch....any of you guys got any ideas what could be causing this...doesn't do it when moving forward only when backing up....wheel bearing maybe?...belt rubbing?...I'm **** about noises I don't think are normal...and it just started to do this recently...(2-3 weeks)....any info or ideas will be appreciated...
I would suggest you put it on a jack and check things out...Like the above poster said,however if it is a Road King the axle has cams on it making it easy to align..Good Luck
