Guys with a 21" Front Wheel
Old 05-14-2010 | 09:31 PM
sh4325's Avatar
sh4325
Default Guys with a 21" Front Wheel
I have a 10 model Road Glide Custom. I am thinking about putting on a set of chrome wheels. 21" on the front and an 18" on the rear. Right now my bike rides and handles really well so I don't want to screw with that too much. Does the 21" front wheel make the bike handle worse than stock or ride rough?
Thanks for any advice!
Old 05-19-2010 | 03:24 AM
tl1000smva's Avatar
tl1000smva
I'm with ya...I'm wondering the same thing. Been hesitant to pull the trigger on a set of wheels because of it...
Old 05-19-2010 | 02:53 PM
floater33's Avatar
floater33
6th Gear
Technically speaking, because of the shorter sidewalls on the tires, it should ride a hair stiffer. But cmon, your riding touring bikes. In my experience, the only thing I really noticed being stiffer is when I lowered the front and back (to compensate for the taller tires). As for handling, I havent noticed any difference. If it wasn't lowered (just had the taller wheel/tire combo) then you could probably lean it over in the turns a bit more. Just my $.02
Old 05-23-2010 | 09:40 AM
MSFLH's Avatar
MSFLH
floater33, I think he's hinting at the fact that he understands that the 21" tire/wheel combo will throw the frame geometry and center of gravity out far enough to affect the handling designed into his chassis. He, like a lot of guys, wants to know what all is involved in getting back to the stock geometry for a safe handling ride.
From what I have picked up on this subject, is that you will need to lower the front to get back close to your factory rake/CG geometry. I need some more info on it myself before I go big. good luck, and good thread.
Old 05-23-2010 | 09:18 PM
floater33's Avatar
floater33
6th Gear
Oh I see. Well, on my personal bike, I havent really noticed any differences your talking about either, seems to ride the exact same. I get a slight wobble at high speed, long sweeping turns. But it did that with stock tires too.
Dragonback
Wheels/Tires
01-23-2016 12:24 PM
brandss
05-09-2012 10:46 AM
knife_edge
10-03-2011 08:14 PM
StanfordMan
Wheels/Tires
08-09-2010 11:00 PM
StanfordMan
08-08-2010 03:38 AM
