straight answer on tire pressure
Quite right! When using non-standard tyres, the recommendations in the owners manual go out the window. You should refer to Michelin and if necessary send them an email to ask for the correct pressures for your bike. I use Avon tyres and their recommended pressures are usually a little higher than the manual.
Hey guys i just called Michelin and actually got a human being right away. He stuck to his guns that if you put the same size on the bike that it came with and use Michelin or Pirelli or whoever, you stick with the recomended pressure from the bike manufacturer. He also said if you play around with sizes, then they could make a recomendation. I also have the wobble in the front end during deceleration starting, so i will check mine today.
The Michelin man can only speak for Michelin! As an Avon user for many years I can assure you Avon recommend slightly higher pressures than in the Harley owners handbook. That information is available on their website, by model and year, so is easily checked. ALWAYS refer to the tyre maker if you fit non-stock brand tyres!
Thanks! I bought my first Harley back in the 70s, when they came on Goodyears. Nothing good about them! They were the best reason to try other brands and I have only ever used the original tyres my Harleys/Buells have come on, then changed to Avon mostly, Venoms these days for my Glide. Avon recommend 38F/44R, which I use solo, but I use 42F/48R 2-up and 44F/50R when 2-up and fully loaded for touring.
