Front brake switch question
Old 04-12-2010 | 11:04 PM
schwangster's Avatar
schwangster
you are right!!!!
I took it apart and was pushing it in to actuate the signal!
It has to come out, and it doesn't.
What is the fix? New switch?
thanks JD
Change your name to Super Dave !
Old 04-12-2010 | 11:06 PM
JustDave71's Avatar
JustDave71
Originally Posted by schwangster
you are right!!!!
thanks JD
nope...in turns it OFF
so...the "nipple" isn't sticking out enough, or not at all, or...?
if that "nipple" doesn't have full travel anymore, and it's not just because something's hitting it, then it's broken and yes you need to replace it. They're not expensive at all. $10 or less. and you can just remove the solder and re-solder your current wires on the new switch, or do whatever, just make sure you get the connections correct.
I can't take credit for anything...just something I learned recently after doing a lot of reading.
Glad to be able to GIVE help here instead of taking it all the time!
Old 04-12-2010 | 11:45 PM
schwangster
THANKS AGAIN.
Old 04-13-2010 | 12:15 AM
JustDave71's Avatar
JustDave71
no sweat, dude. hope you get it back to functioning properly
LowRider68
09-23-2023 06:13 AM
switzead
01-25-2012 08:22 AM
V2Evo96
EVO
08-17-2009 02:08 AM
perpulreaper
EVO
11
08-02-2009 08:23 AM
Hogaholic
01-19-2008 03:26 PM
Quick Reply: Front brake switch question
