Brake line end replacement?
Howdy All...
I'm looking to clean up the front end of my '05 FXST and would like to replace the master cylinder end of my S.S. brake line with a 90 degree banjo, as well as loose a couple inches in length. Any ideas where I could have this done?
Okay... Before the "replace the whole line" birds start singing... A custom length line or a completely new line is not in the budget unless the cost for replacing the end is very close to the cost of a new S.S. line...
I think you have two choices, one cheap and one costly.
The cheap route is to obtain a fitting like you want with a "reusable end", cut the line and build your own. You should be able to find a 90-degree banjo fitting on e-bay or some such similar place. I am sure it is a -3.
The better and more expensive way is to purchase a custom line in the length you want with screw-in fittings, or a new custom line made line from a GOOD source such as Paragon Performance.
You are "wanting to have your cake and eat it too". Anybody that can change the end and shorten the line in a manner that will look like it came off the shelf...is going to charge you about as much as you can pay for a new line in the length you seek with the fitting you desire.
The build-your-own will suit your need, but you may not find the reusable fitting attractive either. I'd spend my idle time poking around on e-bay looking for a ready-made line for a bargain.
