copper brake line
Old 08-28-2009, 04:37 PM
El-Infidel's Avatar
El-Infidel
El-Infidel is offline
Default copper brake line
I was thinkn of making copper brake lines as it would offset the denim black and blacked out components. Any thoughts? Anyone try this or know someone who has?
Old 08-28-2009, 04:44 PM
rickb's Avatar
rickb
rickb is offline
I wonder if it would be strong enough. It might expand under pressure?
Old 08-28-2009, 09:46 PM
omgtkk's Avatar
omgtkk
omgtkk is offline
Like RickB said, I don't think the copper would handle the pressure. I like the idea that you are going for. I would think about using stainless brake line and having it copper plated. Look up Caswell Plating on the web for home plating supplies.
Old 08-29-2009, 07:37 AM
El-Infidel's Avatar
El-Infidel
Whats the max pressure the brake system will put out?
Old 08-29-2009, 07:43 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I also agree that I don't think copper will stand the pressure. I would also say that copper won't handle the vibration very well and may crack from it.
Old 08-29-2009, 02:25 PM
rbabos's Avatar
rbabos
rbabos is offline
Copper will handle the pressure ok, but since it's soft it will continue to leak at fittings since it's soft and vibrations will compress it , loosening the fit. Constant tightening will be needed. Go with time proven steel and you won't have any problems.
Ron
Old 08-29-2009, 02:28 PM
RockyS's Avatar
RockyS
RockyS is offline
I agree, copper won't work long term.
Old 08-30-2009, 07:45 AM
El-Infidel's Avatar
El-Infidel
What about flaring the fitting ends and applying a sleeve behind the flare just like on aircraft? I know that this may seem like I dont want to accept that this is not a good idea...just picking y'alls brains and probably annoying the cr^p outta someone
Old 08-30-2009, 07:56 AM
El-Infidel's Avatar
El-Infidel
Maybe a new idea......the metal conduit used on headlight assemblies for hot rods like early fords....just have to find some type of ferrel to use on the ends I guess to cover steel braid hose (dont want regular steel braided lines......everyone has it lol)
Old 08-30-2009, 09:00 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,446 Likes on 5,032 Posts
DANGER!!! Copper must not be used in making brake lines, it will fail. Not might fail...will fail. It will work harden and crack.
Quick Reply: copper brake line
