copper brake line
08-31-2009, 08:59 AM
Since you have a real boner for copper, but want to remain safe, copper plate the oems. That should give the best of both worlds.
Ron
08-31-2009, 01:32 PM
Dan is right.
For instance. take a little length of a brand new roll of copper. Bends easy to the shape you want. Once----Try again. It's harder to bend. Work hardened.
Always do function first, then form if you can.
02-22-2012, 11:58 PM
I know this is an old thread bud did you ever come up with a solution...I had the same thoughts as you did.
perpulreaper
EVO
07-20-2009 09:00 AM
gliderman
04-02-2008 06:02 PM
David F
08-28-2007 10:04 AM
jammer1
08-02-2006 09:28 PM
HDF Tech
General Topics/Tech Tips
12-22-2005 07:23 PM
brake ,
brakes ,
copper ,
davidson ,
flare ,
forums ,
hardens ,
harley ,
line ,
lines ,
motorcycle ,
plating ,
pressure ,
steel ,
tool ,
work
