Will a 140 fit a Road King?
ME880 on RK
I need a new rear tire on my 2000 Road King Classic and am considering a Metzler ME880. Most of my riding is two-up and occassionaly loaded up with luggage so I am thinking of going to a 140 tire, if it will fit, for the higher load rating. Does anyone know for sure if a 140 tire will fit in the rear fender of a 2000 Road King Classic with no clearance issues? I have a stock suspension front and rear.
belt guard - rubbed. Make sure you check their recommended pressures - higher. Just
google "metzeler motorcycle air pressures" for their site.
Opps -
had to do to keep tire off the belt.
Choosing a 140 is a good move if you travel loaded and two-up a lot. Harley went to the 140 rear with a higher load rating. I now have a 150/80 in my old Evo, using a later spec narrow belt, which is rated the same as the 140.
You can modify the belt guard, remove the belt guard, have issues...or spend $40 on a Pingel Spacer like I did and not need ANY mods:
http://www.pingelonline.com/rear_sprocket_spacer.htm
