how well is the white wall tires "white" lasting
how well is the white wall tires "white" lasting. mine was painted using the white wall tires can. it does not last long and after one month, it was blown and look dirty.
kindly for your commend on those tires that come with white wall.
thanks,
jackie
here my bike using white wall tires paint.
https://www.hdforums.com/forum/gener...-the-bike.html
thanks,
jackie
thanks,
jackie
thanks,
jackie
Using whitewall paint, you would have to re-apply the paint often to maintain the look you want.
Tire sidewalls continually flex as they are being used (especially on motorcycles), so all of that heat and friction will break the paint bonding down.
True whitewall tires are actually part of the tire and have their whitewalls bonded with the tire during the manufacturing process, allowing them to flex with the tire during use.
The problem is that there are a limited number of tire sizes that are available in whitewalls. If you have a size that isn't covered, then you have no choice but to utilize the whitewall paint if you insist on that look.
I hope that this helps!
Cheers
Cheers
Cheers
how well does the true white wall tires stay white, what cleaning solution recommend for that?
jackie
Cheers
I had a problem with the Bleche White. I think it may have become more acidic over the winter. Used it last season, worked great, whitewalls were very bright. Used it last week, didn't make the whitewalls much brighter but stained my wheels something awful. Polished them with Mother's Mag & Aluminum Polish and that took care of them but I doubt I'll use the Bleche White again. I think the Simple Green/Magic Eraser may be the way to go.
