Fatboy rear axle
Old 01-27-2009 | 10:25 AM
GMANFATBOY's Avatar
GMANFATBOY
Stage IV
Default Fatboy rear axle
Can I put the rear axle in from the left side instead of the right, so that I don't have to remove the mufflers next time? It's a 2001 Fatboy.
Old 02-07-2009 | 07:19 PM
snip0721's Avatar
snip0721
you most certainly can. i did my 00 fatboy first time i had rear wheel off. makes things lot's easier later on.
Old 02-08-2009 | 04:56 PM
stroker1948's Avatar
stroker1948
Nope, it's turned that way for a reason. It is possible for the axle to turn and spin the nut off when inserted backwards. Not a good idea safety wise. Thats why the Motor Co. installed it the way they did in the first place.
Stroker
Old 02-08-2009 | 05:59 PM
mtnlvr's Avatar
mtnlvr
I've run mine like that for the last 5 years...no problems. Just be sure the cotter pin is inserted through the nut and loosen the axle nut into the cotter. This way the nut can't work its way loose to allow the cotter to fall out should you not bent the cotter.
Old 02-09-2009 | 07:37 AM
ajayrk's Avatar
ajayrk
It's ok to do that. The MOCO installs the rear axle on late model touring bikes from the left side.
Old 02-09-2009 | 11:59 AM
GMANFATBOY's Avatar
GMANFATBOY
Stage IV
Thanks for your help
dharmon012
03-11-2014 06:24 PM
mayhewconsulting
04-21-2010 12:16 AM
GMANFATBOY
The General Motorcycle Forum
01-26-2009 07:54 PM
TIPN8R
06-30-2008 08:24 PM
wadejesu
02-22-2007 08:04 AM
