Leaking around bead
Leaking around bead
I went out ride the EG and the back tire was flat.
I filled it and looked for nails or screws in the tire.
There were none.
The tire has ride-on in it so it should not leak from a tread puncture.
I sprayed soapy water on the tire and wheel.
It is leaking all around the bead.
The tire is about a year old and has maybe 2000 miles on it.
What would cause this and how do I fix it
There were none.
Rim not being clean when the tire was mounted. Not enough lube used when seating the bead. Bad spot in the tire on the bead.
It could be a number of things, but you said "all around the bead". That phrase bothers me a bit. Usually when you have a leaking bead it's only in one spot. If it's all the way around I want that tire off and inspect both it and the rim closely.
If it doesn't work I'll take it to the shop and have it dismounted and inspected.
Thanks.
1995 Electra Glide Standard.
It was a build up of rubber around the rims.
I had both tires removed.
I had the rims cleaned with a plastic grinding disk. It is softer than the rim.
The tires now hold pressure without leaking.
I was told that this is common in factory cast wheels from this era.
I hope this helps someone with similar troubles.
