Maybe the Parts listing is incorrect ...Below is from a 1996 Factory Service Manual ...
But this is just academic because in practice one is correct and one isn't ... Look in your Cast wheel. Could you even fit those larger flanges through your wheel?
Actually if those dimensions for REAR spacer sleeves below are correct, then the Front and Rear sleeves are the same length
... (because they use the same part#'s Front and Rear)
May be on that bike & year but do not take that as being gospel for all of them. I'd put the calipers to the new one and check the length just to be sure, had a few that weren't.
