21" front wheel
Without knowing what wheel you have it's hard to know if it will fit. That being said, here's how I put a stock '14 SG wheel on my '94 FL with a 3/4" axle.
https://www.hdforums.com/forum/evo-c...-3-4-axle.html
Nothing is impossible, but the front wheel speedo drive is not easy to deal with and that alone is a good reason why his wheel won't work. In addition your wheel bearings are 3/4" tapered rollers and his are 1" ball races and they will not swap over for that reason. For an easy life you need to stay with a wheel that uses 3/4" tapered roller bearings.
