Tire pressures for 21" and 17" tires?
Old 05-19-2016 | 08:25 AM
alabamatanker's Avatar
alabamatanker
6th Gear
Question Tire pressures for 21" and 17" tires?
Looking for correct tire pressures for:
Front- 120/70/21
Rear- 200/55/17
Both say max pressure is 42# on sidewalls.
TIA
Old 05-21-2016 | 09:59 PM
SE120RG's Avatar
SE120RG
I run 42 rear and 40 in the front and it seems to ride good
Old 06-21-2016 | 09:53 AM
bykw2's Avatar
bykw2
I run 42 rear and 40 in the front which works for me.
Old 06-21-2016 | 04:27 PM
grbrown's Avatar
grbrown
The writing on the sidewall is not very useful IMHO! What is the stock rear pressure for your bike? That is probably close enough as a starting point. With both of your tyres, as you are using non-stock sizes you need to experiment a little to find pressures that ride right for you. I have an 18F/17R custom combo and am doing just that.
road glide o8
06-13-2012 03:50 PM
2012fxdc
06-02-2012 04:56 PM
Ramboamt
10-22-2008 10:12 PM
WVleo
08-23-2008 09:25 PM
Kern
08-11-2007 02:09 PM
Quick Reply: Tire pressures for 21" and 17" tires?
