Spoke Thread Pitch
Didn't you mention you have/or had a Husqvarna?
4.5mm nipples
http://husqmotoparts.com.au/find/part/M.4668
4.5mm nipples
Measure the OD of your thread
"googoo" is your friend
4.5mm nipples
4.5mm nipples
The "OD" of the threads of the spoke are 4.30mm/0.170"
9 ga = .114"
8 ga = .128/.129"
#10 thread = .190"
#9 thread = .177" (if there was such a thing)
#8 thread = .164"
4.5mm = .177"
The minor diameter of the spoke threads is about 0.155".
So the actual diameter is somewhere between.
Definitely not 4.5mm/.177".
The #8 thread at .164" sounds good but the 8x32 tap fits loosely in the nipple and the die won't go on the spoke at all.
I don't know where I got it but I have written down that #8 is 5/32" or .15625". Where did you get .164"?
