What is needed to fit 09 or later f.rim on 07
Top Sticky
https://www.hdforums.com/forum/wheel...l-install.html
Different specific wheel, but same theory and process.
Short Version:
Use 25mm axle and spacers (Stock on 2008-2015) with your "New" Enforcer wheel
OR
Use 2000-07 1" ID x 21mm Wide OEM bearing, 2008-15 Internal Spacer Sleeve, your existing 1" axle and spacers. Reduce your 1" spacers width by 6mm (.236). Follow 2000-07 Front Wheel/Right Slider Installation/Spacing instructions (service manual)
OR
Use Aftermarket 1" ID x 15mm Wide bearing, 2008-15 Internal Spacer Sleeve, your existing 1" axle, and some 1" spacers (spacers "should" be a slight variant from your original spacers.
Added Later: (forgot to mention) Also upgrade to Touring Brembo Front Calipers to compensate for the increase in rotor diameter from 11.5" to 11.8"
Short Version:
OR
OR
