17x4.5 wire wheel
Old 12-09-2014 | 07:12 PM
TankSlapper's Avatar
TankSlapper
1st Gear
Default 17x4.5 wire wheel
Howdy,
Got a rear wire wheel and looking for tires. I know i want a bias ply and will run a tube in it for now. Being that it's a 17" wheel, tires selections are mostly tubeless type.
Anybody know what brand tire I can run with a tube? The recommended tire size for this wheel is 160/70-17.
I plan to season the wheel for a few thousand miles and then want to seal it so I can run tubeless tires but since it is brand new I need to ride it for awhile and tighten it up until it settles in.
Old 12-13-2014 | 12:04 PM
grbrown's Avatar
grbrown
There are several brands of suitable tyres available that will fit that wheel, in either 160/70 or 170/60. I have an Avon Storm 160/70 on my Glide. You can use a tube in most if not all modern tubeless tyres. You can also use a radial on the rear, plus a radial or bias front. From what I've read trying to make a conventional wire-spoked wheel tubeless is a challenge! Tubes are more reliable. What bike are you installing this wheel in?
Old 12-28-2014 | 04:24 PM
Percyco's Avatar
Percyco
Just bought a set of Shinko 777's to do this with.....
Blacklightnin
08-16-2012 03:40 PM
NCTURBOS
Wheels/Tires
01-19-2009 07:43 PM
turczytj
06-04-2008 07:29 AM
95Heritage
Detailing
06-04-2008 01:26 AM
HDF Tech
08-07-2005 05:02 PM
Quick Reply: 17x4.5 wire wheel
