Quick and dirty Dynabead install
Folks,
The product works, IMHO, and it lets you get rid of those ugly weights on your pretty chromed wheels. The rear tire in my Road King is a car tire with 3 oz. of dynabeads, and the front is an 18" radial with 1.5 oz. It rides smooooooth.
The good thing about Dynabeads is that they work with tubeless tires or with innertubes, and they are cheap and easy to install. It doesn't make a difference if the tire is off the bike or not, but you have to let the air out first, install the 'beads, then air up
The kit, I added the electric engraver, it makes life easy
Tiny ceramic *****, careful when you open up the bag, because they rollllll...!!!
The kit comes with "filtered valve cores" but they are too long for our application, maybe with innertubes they might work. I reused my old short valve cores with no problem. That fine screen mesh in the valve core is supposed to keep the 'beads from coming back up and plugging up the valve stem, but this has never happened to me, and I only have used the short valve cores
Remove your valve core. After you get the amount of Dynabeads you are going to put in the tire into the applicator bottle, screw on the short hose into the bottle and then into the valve stem. As soon as you tip over the bottle, the Dynabeads are going to bunch up into the valve stem, clogging it up
So you get the electric engraver (or an electric sander, or *****, or jackhammer, something that vibrates, lol) and hold it to the valve stem, then watch the Dynabeads roll into the tire. Then air up and you are good to go. That was waaaaaay too easy.
Link for the company that sells them
http://www.innovativebalancing.com/
Regards,
Regards,
Dynabeads
They have premeasured packets. Go to the link and look at the motorcycle section. The 5 oz packet I had was a leftover from a large truck offroad tire.
Another one of the reasons why its so easy, is that you don't have to have the EXACT amount, like in lead weights. With Dynabeads, if you need 2 oz. and you have a 5 oz. packet, just pour a little less than half in the applicator bottle. Plus or minus a little will do just fine, no worries.
Regards,
Regards,
Yep I totally agree about them working. I was a skeptic, but thought what the hell and gave them a try. No lead on my disc wheels and smooth as silk. One thing I like is they rebalance over the life of the tire. And tires do change as they wear. And yes a ***** works well. Just don't let the old lady see you sneaking it out to the shop.
