2000 FLHTC fuel injected no fuel pump and no spark
8-Ball-
Hello all, new to the forum and my first question here. Bike is a 2000 FLHTC fuel injected. While riding, bike shut down (like out of fuel) was able to restart right after. This happened a couple more times, then would not re-start. Trailered it home. When turning on the ignition switch I could hear fuel pump run for just a second (not long enough to build up pressure) and engine light came on for just as long (just a second while pump was running). While wiggling ign switch could get pump to come on once and a great while, and only for a split second. I looked down in the tank and while pump would flicker and run, I could see fuel moving in the tank. I pulled the pump out and found a pin hole in the fuel line. I've replace the fuel lines and filter in the tank, but still have electrical problem. Pump only comes on for a brief second while rocking ign switch back and forth. I replaced ign switch believing it had shorted, still same problem. While cranking I left spark plugs in bike and checked for spark- none... ANY IDEAS??? Will bad crank pos sensor cause fuel pump to not cycle and no spark, or ECM? Thanks for any input.
Welcome to the forum from Northwest Mississippi!!!
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
