Auto tune issues
Auto tune issues
Last week I installed an PC V and auto tuner. I had upgraded to Bassani 2 - 1's and a big sucker 2 and obviously needed to change maps.
The only issues I had were the threads on the pipes (02 sensor was a little tricky to get in) and keeping the electrical panel cover on. I had to position the auto tune a little awkwardly to get everything to fit.
As a result of that second issue one of the wires connected to that front end O2 sensor came out of the auto tune. I began to get huge swings in my trim. After a day or so of this I found the disconnected wire. Duh... But of course after accepting some of those wild a** trims I'm all screwed up and have pipes that sound like helicopter blades.
My first step was to reconnect. I then loaded a back up map -- of course the back up could be off because of that damn red wire. I got the bike out for test run. Damn wire broke loose again. Back to square 1.
Any suggestions on getting back to a decent tune? Do I simply set the auto tune adjustment to 50% and take big swings at getting back to normal? Do I reload that back up map again?
Welcome to HD Forums. This section is for us to get to know you and for you to get familiar with our site. Later you can ask your tech questions in the appropriate sub forums.
