1979 harley fxe rear brake problems help
I have a 79 fxe rebuilt the rear master cylinder after the rear brake got smoked and the brake would never build very much pressure and then after it sits you have to pump it up but it still is a very spongy brake I also rebuilt the caliper and the same thing no change need some advice
Hello and welcome from Mid-Michigan.
Most will only greet you on the new members board. Technical questions should go in the correct forum for the question being asked.
Your issue may be the brake's master cylinder has worn seals.
Welcome to HDForums from southeastern Michigan. By far you have joined one of the best forums that I have ever seen. Take a good look around and possibly before you can ask a question you will find the answer.
