Reinstall back wheel alignment and belt deflection setting
I have a 2006 ultra Classic 31,000miles. I have taken the back wheel off for my fist time. Always before at dealer. I found a great deal on a new back tire so I cleaned up the back wheel and had Harley dealer put on new tire and balance. I have the service manual for touring bikes for 2006. I put the wheel back on and followed all except for having the belt deflecton tool 10 lb tension item. I have put a couple of hundred miles on the bike and I feel all is fine. The only question i have in my mind is i really am not complete sure i did all correctly. Can any one give me some idea of how to check all with some simple instructions. Im a great carpenter and pretty good with tools and have done lots of work over the years on other types of bikes i have had. This is my first harley and the first bike with a belt instead of a chain or drive shaft. Any ideas are appricated...
thanks.
thanks.
![Icon Toast](https://www.hdforums.com/forum/images/smilies/icon_toast.gif)
thanks.![Icon Toast](https://www.hdforums.com/forum/images/smilies/icon_toast.gif)
thanks.
https://www.hdforums.com/forum/touri...eflection.html
Good luck!
Welcome from Virginia....Really need tool. Also check manual if you should check with driver on or off. My Softail says loaded and I lay across seat and check. If I set it to maximum unloaded, its at minimum loaded. Got my tool off Amazon not too long ago. $24. good deal and quality tool for clone
