Stuck Brake Light
Old 06-09-2011 | 11:32 PM
spockareno's Avatar
spockareno
1st Gear
Default Stuck Brake Light
I can't get my brake light to go out on 07 Road Glide. Changed front switch after it quit working. Light won't go out even after pulling relay. Any help will be appreciated.
Old 06-10-2011 | 06:04 AM
ja57's Avatar
ja57
Welcome from Illinois. Did you have a spacer in it when you changed it? Do a search as this has happened a few times here.
Old 06-10-2011 | 08:20 AM
Wassup8687's Avatar
Wassup8687
Welcome
Old 06-10-2011 | 08:25 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Welcome to the forum. Have you looked at the rear switch? Also does it have ABS?
Old 06-10-2011 | 08:56 AM
KSRoadKing's Avatar
KSRoadKing
Welcome to the forum from Kansas
Old 06-10-2011 | 10:32 AM
spockareno's Avatar
spockareno
1st Gear
Question Stuck Brake Light
I cut the wires to the front switch and the light stayed on. I unplugged the rear switch and the light stayed on. I unplugged the brake relay and the light stayed on. It seems like a short but I got the front switch working for a little while and then it went to continually on. Why would unplugging the relay not kill the power going to the light?
Old 06-10-2011 | 10:34 AM
SIDECAR BOB's Avatar
SIDECAR BOB
did you change the bulb sometime the filaments fuse together and stay on double bright.
Old 06-10-2011 | 10:50 AM
spockareno's Avatar
spockareno
1st Gear
All three rear lights come on.
Old 06-10-2011 | 11:05 AM
spockareno's Avatar
spockareno
1st Gear
I have the adapter that uses all three rear lights for brake lights and all three come on and won't go off. The turn signals won't flash either.
Old 06-10-2011 | 11:10 AM
SIDECAR BOB
try removing the adaptor
Quick Reply: Stuck Brake Light
