98FXDL Primary Questions
Old 12-11-2008, 09:22 AM
SBM's Avatar
SBM
SBM is offline
1st Gear
Default 98FXDL Primary Questions
this is strange. I bought this bike with near 70K on the clock, got it running and the primary chain was rattling in the case. tore it down, chain was stretched to the max along with the adjuster worn out. replaced these items, new gaskets, put new oil in the primary. 100 miles down the road, chain starts making noise, oil on the drive belt and rear wheel, (it was oil soaked when I bought it also but primary drain was loose and I thought this was the source of the oil spray) no oil in the primary. Guessing (from reading forums threads) the trans output shaft seal is toast. Question is, I've heard of blocking engine oil/primary oiling with plugs and running seperate oil in just the primary. How do i do this? Thanks!
Old 12-11-2008, 09:24 AM
tima's Avatar
tima
tima is offline
Take your question to the tech forum and you'll get some good answers. Welcome from the coast of Washington State!
Old 12-11-2008, 09:43 AM
Toolguy's Avatar
Toolguy
Toolguy is offline
Tech forums are calling you. Welcome from Vancouver Island in Beautiful British Columbia.
Old 12-11-2008, 09:50 AM
Blackbird's Avatar
Blackbird
Blackbird is offline
Welcome aboard from Omaha, NE.
Old 12-11-2008, 04:41 PM
Ultra 08's Avatar
Ultra 08
Ultra 08 is offline
Welcome from Virginia. Tech forum is the place to go.
Old 12-11-2008, 07:35 PM
Chula's Avatar
Chula
Chula is offline
Welcome and try tech forum
Old 12-12-2008, 07:18 AM
SBM's Avatar
SBM
SBM is offline
1st Gear
Default Thanks!
Thanks for the "welcome" notes, I knew when i hit the "post" button, I should have been in the tech section!
Old 12-14-2008, 01:37 PM
Chasenfish's Avatar
Chasenfish
Chasenfish is offline
+1 on tech forums.
Welcome from Idaho!
Old 12-16-2008, 10:23 AM
2002fatboy's Avatar
2002fatboy
2002fatboy is offline
Welcome from Atlanta!
Old 12-16-2008, 11:22 AM
BIGschwerm's Avatar
BIGschwerm
BIGschwerm is offline
Welcome from Ft. Campbell Ky.
Quick Reply: 98FXDL Primary Questions
