Bent rear 25mm Axle Sportster Nightster 2009 - Spacers ID 1''?
Old 12-20-2018 | 02:01 PM
JC2on's Avatar
JC2on
3rd Gear
Thumbs up Hi, New to the forum, from San Diego, CA!
Hi guys,
First post here. I bought My first Sportster nighster 2009 1200 with laced wheels. Originally I only have ridden Dirt bikes and still doing so but I have always wanted a Harley. Now I could buy one (used) and I'm pretty happy with it!
greetings to all from San Diego California!!!
(sorry for the below info! im new here oops!)
16x3 with 25mm rear axle.
I’m having trouble to figure out what happen to my rear axle. Apparently, at first sight you could see the wheel out of true, So I tighten the spokes, while the tire was still in the bike, but still the problem was showing. So, I removed the wheel and upon taking the axle out I found out that it was bent on the right side (just after the bearings) where the spacers are. So I bought the new one but I didn’t want it to get it install since I still had the out of true Issue. So, disassembled the pulley and disk. Bought a balancer and truing stand but the tire was what I believe bent. Anyways, my first though was that the tire was out of true. And sent it to Buchanan’s Spokes and rims. To get it align. I didn’t had the patience to tighten the spokes nor couldn’t. I stripped out 3 of them.
So, My question for all of you more experienced guys out theres is:
  • Have you ever had a bent 25mm rear axle? What causes it, probably under tight nut? Or the spacer internal diameters being bigger? I dimension both sides with the caliper and it shows 1”. I have looked up on Drag and specialties shop online and seems that the 1” is the replacement spacer on rear wheels for the Nightster. But I still have doubt about it. Should the spacers have to be same diameter as the axle and bearings (25mm)?
Please any info would help, I would not want to bend another axle again. Ain’t cheap.
I will post a pic of the axle as soon as I get home.
I've been looking for some info on this regarding the ID dimension on spacers for the 2009 Nightster but no luck. hope any of you could help me out.
Last edited by sloufoot; 12-21-2018 at 02:18 AM. Reason: mistake for asking technical data on presentation forum
Old 12-20-2018 | 02:03 PM
critter85's Avatar
critter85
Welcome to the Forum lots of good information here
JC2on (12-20-2018)
Old 12-20-2018 | 02:12 PM
kel03's Avatar
kel03
Welcome to the forums from Ontario, Canada. This is the new members area, post your questions in one of the Mech/Tech areas specific to your question, good luck.
JC2on (12-20-2018)
Old 12-20-2018 | 03:15 PM
JC2on's Avatar
JC2on
3rd Gear
Hi I just noticed, I crossed the section above thanks guys!!
Old 12-20-2018 | 03:33 PM
BuzzCap7's Avatar
BuzzCap7
G'day mate,
welcome to HDF.
Now, for your orientation. Go down the hall on your left to the 1st room. No, wait. That is where Izzo interviews the gals. The 1st room on your right. That is where the commissary is.
We have our own pub .
**** ON THE SERIOUS SIDE ****
Have A Great Day Mate,
BuzzCap7
JC2on (12-20-2018)
Old 12-20-2018 | 06:37 PM
Lou'sUltra's Avatar
Lou'sUltra
Welcome from Ohio
Old 12-20-2018 | 07:57 PM
Dake's Avatar
Dake
Welcome to the forum from Georgia
Old 12-20-2018 | 08:47 PM
DaveE's Avatar
DaveE
Welcome from Pennsylvania
Old 12-20-2018 | 09:14 PM
jblack902's Avatar
jblack902
Welcome from Minnesota
Old 12-20-2018 | 09:20 PM
Uncle Larry's Avatar
Uncle Larry
Welcome To The HD Forum From Michigan, The Greatest Of The Great Lakes States
Quick Reply: Bent rear 25mm Axle Sportster Nightster 2009 - Spacers ID 1''?
