04dyna wide glide electrical headache
I just recently purchased a used 04 wide glide from a dealership for my son once I got it home and rode it only 3 times less than 50 miles put on it then it broke down long story short all the wires from handlebar were just taped together in the frame no connectors not even soldered wires came loose and shorted out I removed wire harness out of backbone and couldn't believe how bad it all was so I guess that's why it shorted out ecm /Icm anyways replaces all wiring handlebar switches and all trying to get it back all back in back bone was impossible no matter what I tried found another way rerouted main harness behind fuse panel on left side then crossed over to right side just in front of battery and zip tied going up back bone on right side there was a location for a wire harness to go into under tank area ran wire connectors from bars to connect to main harness alot easier for any electrical repairs have anyone done this and will it cause more problems please let me know not finished yet getting tank and fenders all repainted
Has anyone done this was this a big mistake
Has anyone done this on a dyna wide glide or am I looking at it causing more electrical problems I'm trying to fix this bike and give to my son for high school as a bday gift I tried running main harness thru the backbone several times and it keeps getting stuck about mid way up there has to be something stuck up in there so I have no other choice but to go up the right side of back bone has anybody done this will it work or will it cause other problems
G'day mate,
welcome to HDF.
Now, for your orientation. Go down the hall on your left to the 1st room. No, wait. That is where Izzo interviews the gals. The 1st room on your right. That is where the commissary is.
We have our own pub .
**** ON THE SERIOUS SIDE ****
Have A Great Day Mate,
BuzzCap7
welcome to HDF.
BuzzCap7
Welcome to the forums from S.W. Iowa! This section of the forum is for introduction to the group. Post your question in the tech/electrical section. I'm sure the guys in there would be able to help you out.
Welcome from Hampton Roads Virginia. Sorry to hear of your problem. Had it been a car, in VA, you could have taken it back.
Harleys are really hard to buy used since people with no mechanical ability buy them brand new and modify them.
Mostly they sit and when they are totally junk, they get rid of them.
Best bet unless you know what you are doing is junk it.
It's cheaper to buy a new one as to fix it unless you can do your own work.
I sure would not do to someone else what the dealer did to you.
