FS: 2007+ Fatboy Rear Fender And Struts
Hey Gang,
I have a spare rear fender with struts (both inner and outer) that will fit 2007 and later Fatboys/Softails with 200 mm rear ends. This came off a Fatboy Lo so everything is in black.
Everything is in good shape but it will all need to be refinished. This is a good set up for someone looking to do custom color work or even chopping. The fender is structurally fine but will need to be repainted. It currently has black primer on it. The struts are all fine but will need fresh powder coating. The inner ones could be run as-is since you don't see them under the outer covers. I also, have a stock style tail light and license plate bracket that I can include if you need it.
I will post some photos when I get home tonight.
I would like to get $175 shipped to the lower 48 for everything mentioned above.
Thanks,
Skeez
Thanks,
Skeez
Gleb
04-27-2012 07:32 AM
