Want To Buy Motorcycles/Parts/AccessoriesLooking for a Motorcycle or a part to help get your motorcycle back together? In search of a deal on used leathers? Post your wants here! Please read the rules for posting in this section.
I'm in the process of installing dual front brakes on my 2005 Dyna FXD - I have everything except for 11.5" front rotors. FL series caliper/rotors will work up to 2006. Low mileage preferred. Please PM me.
Shiny side up!
Reason: n/m
I'm in the process of installing dual front brakes on my 2005 Dyna FXD - I have everything except for 2 x 11.5" front rotors. FL series rotors will work up to 2008. Low mileage preferred. Please PM me.
Shiny side up!
Johnny, aren't you using Vrod/Touring Brembos...yes? If so, you need 11.8 (300mm) rotors
Hey Brother, yes I was but changed my mind as both the M\C and lines are DOT5 rated and since I found a matching caliper here I can avoid any cross contamination and possible seal issues.
Ok, but be aware as to those "2000-07 Touring" Cals...HD started using DOT4 in 2005-later Touring. So if they are 2005-07 cals they have been running DOT4.
...that caliper sold, but I found another under Ebay from a 2006 Electra Glide, stamped 05 on the back - $55.00 USD ($72.00 CAD) including pads and expedited shipping. I'm assuming that any DOT4 residue that might be remaining should be flushed out thoroughly before installing...
Reason: right hand caliper frenzy.
