engine light?
engine light?
hey guys im new to this forum. i just traded my 06 883c for a 06 VRSCR street rod. i turn the bike on and a engine light comes on and stays on for a few seconds and then goes away. this may sound dumb but i never had this problem with my 883c. any help will be appreciated. thanks
RE: engine light?
ORIGINAL: ffsaulshd
well it does that but after you actually crank the bike it comes on again and goes off after a few seconds.
I forgot to add---the light coming on for about 4 seconds also indicates that the fuel system is pressurizing up, and the bike should not be started until the light goes out. If it has happened before, you probably have not hurt anything, but from now on, try to avoid starting the bike until the light goes out---at least the first time it goes out.
ORIGINAL: ffsaulshd
nice bike by the way!
RE: engine light?
I forgot to mention that the light relighting is something that the stealer can clear, if you didn't already know that. I also have heard, but am not sure, that you can disconnect the battery for a couple of minutes to clear the code yourself, but this will also clear your clock and it will have to be reset.
