SE V-Rod
RE: SE V-Rod
From what I hear the CVO Ultra's will be built every year till they cant sell anymore (they are harley's hottest selling highest profit margin bike) the 05 CVO is 180 tire with cnc ported heads the 06 and all later 1250's were sand cast heads here is my 05 VRSCSE in the rarely seen candy blue...
RE: SE V-Rod
ORIGINAL: agedwards63
RE: SE V-Rod
2005 VRSCSE had 180 rears, wide pulley, ignition located under the seat.
2006 VRSCSE2 had 240 rears, narrow pulley, ignition located under right side cover. They also started putting on Brembo Brakes in 2006 and switched to Dot4 brake fluid. The front rake was reduced to 34 degrees (from 36 degrees previously) by taking 2 degrees out of the triple trees.
Am I missing anything? I think I am.......
RE: SE V-Rod
RE: SE V-Rod
ORIGINAL: rjrivero
2005 VRSCE had 180 rears, wide pulley, ignition located under the seat.
2006 VRSCE2 had 240 rears, narrow pulley, ignition located under right side cover. They also started putting on Brembo Brakes in 2006 and switched to Dot4 brake fluid. The front rake was reduced to 34 degrees (from 36 degrees previously) by taking 2 degrees out of the triple trees.
RE: SE V-Rod
ORIGINAL: eazy
I think you're missing the "s" (VRSCSE and VRSCSE2) [sm=icon_stickpoke.gif]
ORIGINAL: rjrivero
RidenChrome
Screamin Eagle CVO Models
04-10-2012 01:45 AM
