Jus curious......
RE: Jus curious......
It really depends on the gearing. The older Vrods had a 30 tooth front pulley while the newer ones have a 28 tooth front pulley. The 28t will accelerate quicker, but reduce the top end speed. With a 28t pulley you should be able to get to low 140's and low 12 second 1/4 mile times with a decent rider. The 30t pulley will get you to the upper 140's, but the 1/4 will increase to mid 12's. A very good rider can get a stock Vrod with a 28t pulley into the high 11's, but he needs to be very good at launching at the right rpm.
1 Post
My V-rod only goes 100mph...as far as I know. Supposedly 142 with the 28t and 148 with the 30t. Don't hear of many people tweaking the map and adjusting the redline to 10K. I guess it's better to be safe than blow an engine at 150+mph.
I have to keep telling people that the V-rod isn't the fastest bike on the road, but it is one of the top 3 muscle cruisers. If you ask a V-rodder, they'll tell you theyown the best bike ever built. If you ask an M109or V-max owner, they'll tell you the V-rodder has the best bike ever built.
Wait...something doesn't sound right. I'm not sure what it is.
Found it!! I've had my V-rod up to 103.
ORIGINAL: whylee
Then add in speedometer error. When my speedometer reads 100 MPH, its actually 94 MPH checked with GPS.
ORIGINAL: eazy
142 mph on the highway with me riding it.
Not to mention the other two.
1 Post
ORIGINAL: DesertSpeed
