Last night I decided to pull out my bike for a ride and I noticed that the right signal in the cluster is dim (see photo) any idea of what is causing this issue? The front and rear light blinkers are working fine.
The above photo was taking using the hazard lights, you can see the difference on how bright one is and how dim is the right one.
I'd start with reseating the connector on the back of the instrument cluster. Pin 4 on the connector is the right turn signal circuit. Might be loose or crudded up.
